running rich all the time
stocker97tsi
50
Mar 29, 2007
South Bend, Indiana
so my car runs rich all the time..i mean from start up, through all the gears and everything. Its so bad that i can't even get up to boost because it starts to sputter really bad..could it be a bad mas? or any other ideas or how i can check it? thanks for the help
would that cause it too be rich all the time? i thought that it would only be rich under boost if there was a leak
Boost leaks generally cause poor performance (loss of power) and a RICH condition as metered air is leaving the system while the fuel to be injected has already been calculated. Even if you can hit full boost (with a boost leak) you are losing out -- the turbo has to work overtime (spin faster) to maintain peak boost. This will tend to increase intake temps, too. So a boost leak, which will tend to make you run rich, can actually lead to detonation as well!
Taken from http://www.thumper300zx.com/z32/boostleaks/boost_leak_guide.htm
Read that, it doesn't only apply to twin turbo's.
my a/f gauge is spiked all the way up, im running through gas like crazy, and there's black smoke..also smells rich..does anyone have a write up for how to do a boost leak test? thanks
Check your O2 sensor. Mine is a N/T so i wouldnt know about a boost leak problem. But i have the same problem with mine running really rich all the time and it will "chug" on me alot because it so rich. I know my problem is my 02 sensor.
