Running Lean and Smoke
laynbdyon20s
189
May 27, 2006
Alhambra, California
Just rebuilt my turbo T-28 now, and my car smokes. When my turbo died, I found a lot of oil in my lower intercooler pipe, so oil was going into the motor. I'm thinking all the smoke now is from all that oil left in the exhaust, intake, etc. When I turn the car on, it doesnt smoke. If I do a hard pull in 3rd it begins to smoke. It smells like oil. I checked for shaftplay and there isnt any. There is also no oil on the blades. so i'm thinking its leftover oil. If it's running lean, which it probably is since i had a t-25 before, would it smoke?
The smoke could definately be the left over oil. I would watch it and see if it gets better. Also your car is probably running lean due to the increased airflow from the new turbo. I would recommend you get some type of fuel management to compensate. The car being lean though would not cause the car to smoke.
I have an S-afc2 with 660 injectors. I knew it wouldnt smoke if I was running lean. I just wanted to make sure. I was trying to convince someone that. I'll get it re-tuned after "breaking in" the turbo. Is there a specific way to break it in? I was told no boost, for the 1st 500 miles, then change the oil.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
