420A RPM problem/aftermarket tach
adio_67
Sep 21, 2010
Babbitt, Minnesota
Okay i have a 96 talon nt and i have an aftermarket tach and i hooked it up to pin 73 white wire on the ecu and my rpms read only half of what they should, ive searched and searched i cant find the answers please any help will be appreciated, and i know the big tach are pointless in NTs but i like them thanks again.
yeah its set for 4cyl and it says connect to 12v source so idk? its really bumming me out.
Well there is one lead on the tach that goes to +12v. Do you have a good connection to ground on the ground lead? Are you sure you're not firing on just 2 cylinders? I suppose you could try temporarily connecting it first to ECU pin 3 and then pin 11 (coils primaries) just to see if it works but for sure you'd read half then. Or maybe you have a bad ECU for the tach signal.
