rod bearing question
superpenguin
44
Jan 22, 2011
bradley, Illinois
I have heard of a few people that have spun rod bears on the 4g63. Which rod is it the normaly spins or is just random?
Thanks guy. I was going to take one rod end off and one main cap just to check sence I don't know how much my car was beat before I got it.
You will know if you got a spun bearing. The rod should have very excessive play back and fourth. Like able to wiggle it.
If it's a 7 bolt and you plan on using the engine, don't remove the cap to look and put it back on, the rod bolts are TTY, and you will need to replace them if you lossen the nuts.
