FLASH1970
- 1,264
- 11
- Aug 22, 2005
Lake Geneva,
Wisconsin
Hello all, my machinist noticed a problem with my valve spring retainers. He saw the outer edge chewed up around about half of my valve spring retainers. Some just had tiny knicks, some were ok... It would appear that the roller wheel from the rocker arm is hitting the retainer. I don't have a picture but I tried to draw the problem so let's try to keep the laughter to a minimum. Just in case you can't read the pictures, the words in the first picture are, "RETAINER", "VALVE STEM", & "INTERFERENCE FROM ROCKER WHEEL". The second picture says "VALVE STEM" & "RETAINER". I tried to draw the outer edge chewed up. I have supertech dual valve springs w/ titanium retainers and 1mm oversized vlaves. If anyone has any ideas or suggestions, feel free to chime in. Thanks in advance.
