Ride Height Problem!
scorpin
Mar 2, 2006
Hayward, California
Ok guys I need a little help here, My brother just bought me some KYB AGX's and Eibach prolines for my birthday a few weeks ago. My problem is this after installing them we measured the right ride height and noticed that it seems to be 3/4's in higher on the right side then it is on left. and the car will bottom out on left the side after hitting any medium to hard bump or dips in the roads. I changed the struts and springs because the left front was completely blown and leaking and one in the rear too, I not only changed the struts and springs, but the struts mounts, boots, and springs isoloators too. It really bothers me that it still bottoms out. any suggestion would greatly be appreciated. I love this car, but if can't fix the ride height problem and make the car perfect again, then I no longer want the car and will sell it.
There are no "prolines." You either have the Pro-kit or the Sportline springs, which are much lower and often problematic.
I installed some Tokico Blues and notice my passanger rear is ~3/4 - 1 inch higher than the driver side rear. The fronts are right on the money for ride height with each other. Any ideas? or is that just a natural thing?
I have the same problem with my sportline. Driver side is lower than the pass. ItÂ’s not the weight problem everyone claims. I had different springs before and it was not noticeable. The weight is not that much for you to notice.
My car looks slanted when you look at it. I will be changing the springs to see if it solves the problem, going with Progress Sport Springs, eibach is just overpriced crap.
