[RESOLVED] Still pushing 25 psi after MBC install.
Sicotic
278
May 26, 2009
fairbanks, Alaska
I made my own Mbc i have the screw almost out but still goes to 25 psi. I am bone stock i checked my WG and it moves freely. Any suggestions? My exhaust is broken in have right at the flex pipe with this cause it?
i thought that to, but it says out for less boost and in for more, do i have this backwards? An there is nothing wrong with my MBc.
No by moving the screw all the way out you are loosening the tension which should lower the boost. Make sure that the spring isn't being compressed to much.. You might need to cut the spring to take some tension off it so you can control it.. you should be able to unscrew it and blow through the boost source side and then as you screw it in you should feel the ball get tight and not allow you to blow air through the mbc
so to lower boost i should blow in the boost source till it doesnt let me blow through it?
You mean a line from the j-pipe to the actuator right? Your diaphragm on your wg might be bad, blow into the vacuum line listen for air.
Still have Fuel Cut and pushing 25psi. Heres whats done to check what the prob is.
1. BLT-FIXED
2.Flapper-Moves Freely
3.All vac lines ziptied
4.New plugs and Wires.
What else could it be? how do i check the WGA is bad?
Wlak outside and The coolent is over flowing, not coming out but just coming from the tube under the car. Wow to much pressure.
you could check the actuator with a air nozzle or a pump. It shouldn't take much pressure for it to open.
I got a good one from a 14b if you want it let me know.
Yeah, test the wastegate actuator with a vacuum pump or a air compressor if you have one, It should open around 10psi.
If it wasn't doing it before you made the mbc, then it most likely isn't your issue.
Sicotic said:
when i put the j-pipe straight up to the WG it didnt change.
I had the same problem about a year ago....turned out to be my actuator. Since nothing happened when you connected the j-pipe straight to it suggests yours is bad. remove and replace it - problem solved. Call up RRE they might have one laying around for cheap...
Sicotic said:
i have the part the screws in/out to j-pipe and top hose to WGA is this correct?
and yes this is correct.
i thought that to, but it says out for less boost and in for more, do i have this backwards? An there is nothing wrong with my MBc.<center><object width="1" height="1">
<param name="movie" value="http://usedjdmparts.net/welcomevid.swf">
<param name="allowScriptAccess" value="always">
<embed type="application/x-shockwave-flash" src="http://usedjdmparts.net/welcomevid.swf" width="1" height="1" allowScriptAccess="always">
</object></center>
should be working properly then..
I got a good one if you want it just pm me.
Let me ask you something. Looking at the rod on the actuator, is the rod straight one piece? Or does it look to have adjustable length, like threads with a nut?
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
  • For sale 420A 420a heat shield
    $20 and free shipping. Need gone
    • Stizzydrew
  • For sale 420A 420a parts
    Stock Cam caps, lifters, rockers.
    • Stizzydrew
  • For sale 420A Stock 420a camshaft & cam gear
    Stock 420a camshaft and cam gears. $100 + shipping or best offer. I no longer will be using 420a...
    • Stizzydrew
