DGajre777
DSM Wiseman
- 4,772
- 132
- Jul 16, 2004
Orlando,
Florida
I bought Corbeau FX Pro seats and ran into trouble with the seat bolt. The corbeau brackets suck which I knew. While installing the seat 2 days ago, the bolt went in at an angle and I stripped it. I took the seat out, put a bolt from top and it goes all the way in. If I put the seat back on, there isn't enough space for me to put a wrench of any kind to turn the bolt to keep it straight.
I know that the OEM bolt with "7" marked on it is a Class 8.8 metric bolt. I was thinking that I could get a longer Class 8.8 bolt, jbweld the bolt (couldn't hurt), tighten it into the hole with a wrench without the seat on, let the JBWeld dry, cut the head off the bolt (might take a while with a dremel), put the seat on and then put a class 8.8 hex nut on the bolt.
Will this be safe if I get in an accident? Should I get the bolt spot welded after I bolt it in? I am not even going to try to cut a Class 10.9 metric bolt and I don't want to drill holes under the car to mount the seats in.
Any ideas?
Any ideas?
The pic below is from the passenger bracket.
