[RESOLVED] Need help with oil pressure gauge wiring.
bbolca00
30
Apr 9, 2008
fort smith, Arkansas
Anybody know what wire on my ecu do I tap my electronic oil pressure gauge wires to? i have a 97 Eagle Talon Tsi Fwd and if you can help, it would be greatly appreciated. Thank you and have a blessed day.
The ECU doesn't have a connection to the oil pressure.
Aftermarket gauges usually include senders. They aren't usually compatible with the factory sender.
You'll probably need to buy the associated pressure sensor. If you stock gauge doesn't work, just put the new sensor in that sensor's place.
thanks guys. Yeah my stock one works,but I would rather be able to have a real readout. wheres the sending unit located? on the back of the block? pully side? pics would help if possible.
