[RESOLVED] Ebay Steering Wheel HELP
here a pic of it installed easy to install till you start to question yourself and think how it works.
I got the same one. the only way I could get the signal lights to shut off is to have the wheel off to the left a bit. I just stratened it out and manualy work the signal. for the cruse, and horn I'm still working on them. I took the swivel out and rewiring the cruse & mounting it some ware. the horn, if I can't figure it out I'm just going to put it on a fake nos button.
why wouldnt your turn signals work perfectly. All the connections to the turn signal can be plugged in. And for the horn i just cut one of the plugs that connected to the clock spring that i believe was the power for the horn and wired it to the horn of the steering wheel. I still havent checked if it worked, probably wont i never get things right the first time
my signals work, but the signal cancel dosen't line up. If I don't turn the wheel far enough the signal dosen't cancel. The horn will be fixed now, thanks I didn't think of that.
  • Wanted 6 bolt NT water pipe
    • chrisman287
