Removing the Head of a 420a Block, Question
Eclipsemblue
356
May 8, 2004
####DSMTUNERS, Maryland
Hey ppl i was just curious how to get the head off the 420a, when i take off the valve cover and the cams are there suppose to be some kind of bolts inside there that hold it onto the engine block, if not can someone please correct me. Thanks
Removing the head involves closing the hood, calling a mechanic and a tow truck. Then the next step would be insuring that the car gets to the repair shop and that you pay the nice man that just towed the car to salvation.
Doug
yeah listen to him man! i tried to change my headgasket and it didn't work out to well. well i got everything off and on right, i just messed the timing up. so most def just shut the hood, and call a tow truck to get it to the shop! some stuff you'll learn you can do on your own....but once you work on the car more and learn more about it you can do that type of stuff....good luck man and take it easy!
  • Wanted 6 bolt NT water pipe
    • chrisman287
