Relay for Nitrous System
NAH_56
Aug 29, 2007
Al-Khobar, Asia
Hi'
I am to build activating system for my new nitrous system. My car is a GVR4. The idea is. activating safety nitrous system especially at lunch & when need it any other time. I fitted a safety main switch from ignition to a relay. Now for the activation' fused wire with a push button and a throttle switch (full open to activate).
For launch I am thinking to create a (Zero Ground to activate a relay) I will use the clutch switch at the pedal. I want the system shutoff when Clutch pedal pressed :aha:
Any body knows how can I do that or How to make Zero ground to activate relays?
Edit: I will find another way Thanks all
The way to activate when clutch pedal released. A micro switch. It will be the ground source for the nitrous relay. Another micro switch will be at the throttle.
