cyrez187
- 359
- 0
- Dec 12, 2003
kelowna,
why cant i hit redline in my car till the rev limit kicks in?? the max i can get is 6100rpm is that right? thanks
miamieclipse said:Wait its a 5sp and limits you to 6100? Those have fuel cutoff at 7200.......Shit automatics are controled at 6500................strange
Uh... fuel cut is on turbocharged motors.speedy13 said:no thats definatly wrong.fuel cut is supposed to be at 7300 rpm.is your cel on?
Because you're normally-aspirated.cyrez187 said:so does anyone get why i cant hit fuel cut>
Are you going to tell us what gear that's in?cyrez187 said:so u guys dont know why i cant get past 6100rpms?
speedy13 said:DEFIANT-I know your a moderator and all,and since you are,if your ever in miami i'll let you take out my baby for a spin and redline it so you can bounce off my 7300 rpm fuel cut.I mean i've done it more than once and i also lost a race cuzz of it so i know for a fact 2gnt's have fuel cut.O and this was at 60 mph,from 2nd to 3rd , not at 130 mph
aliczander said:are you double clutching because if your not your gonna loose more rpms between gears
GSGoinFast said:ya thats your rev limiter, and if you lost a race from it, then that loss was from poor driving and not shifting before your rev limiter kicked in. i mean its not like it was a surprise that it would do that. or did you honestly not know? shift around 7000 rpms, a little past the power band but you stay higher in it in the next gear.
cyrez187 said:didnt change anything doesnt matter what gear im in still wont let me go past 6100
aliczander said:cough cough *bullshit* cough cough
Max engine speed MT 7300 rpm (electronically limited)
Max engine speed AT 6464 rpm (electronically limited)
i would have to say the reason why you cant get past 6100 is because you dont have the power to get that high
try going though the power band
go up to 4 grand dump the cluch
then shift at these points
1st gear: 5800
2nd gear: 7200
3rd gear: 6500 - 7200
4th gear: 7000
because in my personal experence with my car when i shift though the power band like this i get up to 120 super quick then it takes a little while to get up to 135-140 shes got it in her it just takes her a little while to get up there she will hold 65-67k stong in 5th but she needs some road behind her to get up to 7k i didnt have enoughf road to get higher then 7 k but shes got it in here i ran into trafic though so i had to slow down
and when you shift dont let off the gass when u push in the cluch just keep goin
try that and get back to us see if that wokers any better for you
