Rear trailing arm rusted apart
I would find a car in a junk yard that isn't rusted there and remove the mount by drilling the spot welds out and weld them on yours. Hopefully the metal that the mount attaches to on your car is not rusted thru or else it will get quite a bit more complicated.
Yea it is for sure your old one. I'm glad to see it was kept up on the maintenance. The kid told me about his brother too and it had a dented fender and it was fixed by him. I couldn't believe I missed this when checking over and really can't believe he let me drive it over an hour home like that. As far as I can tell I have found a bad wheel bearing, the hole rear suspension/ sub frame is rotting terribly, the stock bov is leaking at just a few pounds, and one of the tranny cooler lines look like its leaking. Other than that it runs great.
Also thanks for everyone's ideas and replies. The passenger side was fixed before so I am just going to get the same thing done on drivers side.
Fixed! For now
Dented fender? Hmm...
Did they at least replace the passenger side rear lower control arm? I hope so, it was rusted in half. Here's my photobucket of the car if you're interested.
96_Talon pictures by ehues - Photobucket
And just so you know what you have, below is the parts list from Extremepsi for maintenance done to the car at 58k miles.
It also has a newer alternator from Napa that I put on at 70 or 80some thousand miles.
OEM Radiator Cap : $10.53
OEM Heater Hose Kit : $18.50
OEM Radiator Hose Lower : $14.26
OEM Radiator Hose Upper : $13.36
OEM Thermostat Kit : $24.00
OEM A/C Belt OEM : $21.00
OEM Alternator Belt : MD310616 $7.57
OEM Power Steering Belt : 2G-MD310617 $8.50
OEM Engine Oil Pan Drain Plug Gasket:3 $7.50
OEM PCV Valve : 2 $12.50
OEM Valve Cover Gasket Set : $48.00
OEM Water Pump
OEM Water Pump Gasket : $4.73
OEM Water Pump O-Ring : $3.25
OEM Camshaft Oil Seal : 2 $18.50
OEM Front Main(crankshaft) Seal : $14.72
OEM Cam Angle Sensor O-Ring : $2.48
OEM Oil Filter : 3 $19.50
OEM 4G63 Balance Shaft Belt : $31.50
OEM 4G63 Timing Belt : $69.00
OEM Timing Belt Tensioner Adjuster $79.00
OEM Timing Belt Tensioner Pulley : $32.25
OEM Balancer Tensioner Pulley: $42.80
OEM Timing Belt Idler Pulley : $36.50
Redline Water Wetter: 12 oz Bottle $9.95
NGK Copper Spark Plugs (BPR6ES): $10.00
Yea they fixed that actually. It is really good to see a list like that. Thanks for those pictures, let's me see what it's been through haha. Small world.
