rear toe problems
ntalon
Mar 7, 2005
Kincardine,
Ok this is what happend. i was ajusting the rear toe and the bolt broke and it is seezed in so i took the whole arm off and had the bussing and bold pressed out is there anyplace i can JUST get the bold and bearing?
Thanks
You mean the bolt and the bushing? The bushing is NOT available at the dealer. Normally the whole arm is replaced. The bolt is available and you can get them from mitsubishiparts.com if you can wait a few days. It's not listed on the site. You have to call and ask for it.
You may be able to get a used bushing, but they are notorious for rusting as yours was. I'd just get the arm.
i think ive got it figured out i pulled the arm off took the bushing out drilled the bolt out and got a new bolt so i think im good . thanks!!
Hello,
At what level would you rate this job? Curious. I have to replace mine on a 1g Tsi AWD...I have the parts on order...should be ready for Wednesday.
Thanks,Will
i would rate it a 1 if you were just replaceing the control arm replaceing the bushing probably a 1 as well just need a press to replace the bushing
