mac 108
- 213
- 3
- Feb 15, 2005
Memphis,
Tennessee
I have a 92 AWD without ABS. I started to replace my rear brake pads, but I can't get the piston to turn like the Haynes manual describes. What can I do?
mac 108 said:I have a 92 AWD without ABS. I started to replace my rear brake pads, but I can't get the piston to turn like the Haynes manual describes. What can I do?
I dont recommend doing that though. Try to find the tool that steve posted.VelocitàPaola said:These types of pistons utilize a different mechanism altogether than the ones found on 2g's. Rather than having hydraulic pressure simply expand the piston axially, these expand axially via radial movement along a series of threads (i.e. similar to a screw). In order to get it to return to the original point, the piston needs to be screwed back in, which usually requires a special tool, although I've been able to ghetto-rig the tool when in a pinch.
Despite the fact that these are found on 1g's, neither style is particularly "newer;" I've seen both styles of rear disc brakes on many cars.
I think I got it. Still just not understanding how pressing the brake rotates the rod to push out the piston. If the brake system still requires fluid, some part of it has to be hydralic.steve said:I'm not sure how to explain.
As the pads wear the piston extends. They don't retract all the way back in but just back off a little.
The threaded rod is the self adjuster for the parking brake actuator. When you use the parking brake it doesn't cause the piston to thread. It turns a cam that pushes the rod straight out the small amount needed to clamp the rotor.
The piston threads on the rod during normal braking. The part inside the piston that threads on the rod is what turns. The only time the piston turns is when you thread it back in. The pads usually have little nubs that fit into the spots on the piston so it can't rotate
These are called integrated parking brakes. The 2Gs use a drum in disk parking brake that actually has more parts than this.
steve said:These are called integrated parking brakes. The 2Gs use a drum in disk parking brake that actually has more parts than this.
justin0469 said:I think I got it. Still just not understanding how pressing the brake rotates the rod to push out the piston. If the brake system still requires fluid, some part of it has to be hydralic.
VelocitàPaola said:Pressing the brake [pedal] does not rotate the rod; Pascal's law simply takes effect to squeeze the piston up against the rotor via hydraulics.
The only time the rod rotates is when the e-brake is pulled (which is based off of a cable actuation system); when this happens, the whole piston assembly permanantly (until you change the pads again) moves closer to the surface of the rotor.
steve said:I don't think this is correct.
When you pull the parking brake the cable pylls a lever atached to the cam. The cam in turn pushes a short link rod the other end of which rides in a cup at the base of the threaded self adjuster rod. The piston is threaded on the self adjuster rod as we've discussed. This is what converts the pulling of the lever to the in and out of the piston.
There is little to no rotation of the self adjuster rod in this movement.
