Rear bearings and ABS
wilfredorivera1
Apr 15, 2005
cleveland, Ohio
When I start driving my car even at slow speeds I can hear weird sounds on the back, my friend told me that it was the sound of the road due to my car is so low to the ground, but I think that my rear bearings are going out. Well I went to advance auto parts and I purchased 2 hub assemblies for the rear (60 dollars a piece). Ok here are the questions:
Can I remove the caliper and rotor with out disconnecting the lines?
Would I be able to put everything together and have my brakes work the same way?
I really do not know anything about ABS and I am kind of scared I am going have to disconnect the lines.
Can somebody please tell me the steps of bleeding the brakes just in case?
Thank you
Will Rivera
:confused:
1) yes, hang the caliper to the spring with a bungie cord after removing it so as to not stretch/damage the flexable brake line.
2) yes
3) http://www.dsmtuners.com/forums/showthread.php?t=100353
