silentscreamer
- 106
- 1
- Oct 11, 2008
Moncton,
NB, Canada
I was replacing the backing plates for my AWD talon the other day and noticed the ones i got from the classifieds were for a FWD turbo (my mistake) so the seat were the hub goes is much smaller diameter. i was wondering since i already have the backing plates and cant find any other cars in scrap yards around here if i could cut the hole larger for my awd bearing and them drill the 4 mounting holes. theoretically the backing plate sees no load untill the handbrake is pulled and that is when the car is at rest so it shouldnt be too bad should it? also if any one has a hub out and can meaure the ouside diameter of the seat then i could start cutting away once i find out if it safe or not. also the reason behind replacing the backing plates is the guy who owned the car before me grinded them down,cant figuer out why yet, to the point where i cant put the retainer pin in on one side or else i would just use my own on the car.
thanks ahead.
thanks ahead.
, thanks for the input
Can someone help me out here? Once I do get the backing plate will the shoes and hardware from the fwd subframe bolt on to the awd backing plate? Thanks.
