- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse Spyder GST
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- CAI w/ 4" Pipe and K&N Filter , PTE 6262 JB w/ Ceramic Coat & DEI Turbo Blanket, VRSF FMIC, TIAL Q BOV, Joe P MBC, 63mm TB, Magnus V3 Intake Manifold, Ceramic Coated & DEI Wrapped Exhaust: (STM T3 Tubular Exhuast Manifold w/ TIAL MVR 44mm Wastegate & Dump Tube, Custom 3" Tubular O2 Housing) Wrapped Megan 3" DP w/ Cat Delete, Custom 3" Catback to Magnaflow Muffler, Walbro 255lph FP w/ Rewire, FIC 950cc Injectors, Aeromotive AFPR, MSD 8.5mm Wires, NGK ES Plugs, Prothane Mounts, B&M 11x10" External Oil Cooler, Fluidyne Radiator.
- Mods-Engine
- 4G64 Block & Crank w/ Ceramic Coated Wiseco Pistons, Scat Rods, Ported & Polished 4G63 Head, Standard Valves, Kelford 272 Cams, Skunk2 Adjustable Cam Gears, Crower Valve Springs & Ti Retainers, Fel-Pro MLS Head Gasket, ACL Race Rod & Main Bearings, ARP Rod & Main Studs, L19 Head Studs, BSE.
- Mods-EMS & Logging
- ECMLink V3, Summit Racing Fuel Pressure Gauge, Glowshift Boost, Oil Temp, Oil Pressure Gauges, Voltmeter on Pioneer deck.
- Mods-Drivetrain
- AWD Conversion, Fidanza Flywheel, Competition Stage 4 Clutch, B&M Short Shifter, Under Hood Solid Shifter Bearings.
- Mods-Handling
- Eibach Prokits, Tokico Illuminas, Strut Bar, Slotted & Drilled Rotors w/ Ceramic Pads, Battery in Trunk, 18" Enkei DM5's w/ 225/40 tires, CF Hood & Trunk.
- Parts Wishlist
- Lightweight Seats, Water/Meth Injection, PTE 6466 BB, 245 Tires, Roll Bar
- Background
- Two DSMs combined into One.
- 1/4 Mile E/T
- 00.000
- 1/4 Mile MPH
- 000.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 00.000
- 60' Time
- 0.000
- Dyno TQ
- 000.0 lb/ft
