radiator
tsi009
35
Nov 6, 2007
Pinole, California
Help pls guys,
My dsm got coolant leak like once a week on the passenger side at the bottom. I dont know why. I took out the radiaotr to clean and check it fines. I am thinking just change the radiator to be safe. Can I use non turbo radiator for it?
are you sure it's the radiator that's leaking? check your top and bottom hose first to see, then if it's really the radiator i suggest you go online and purchase an aluminum one, or go to your local kragen or auto parts store and pick up an OEM one, depending on the purpose/use of your car i.e racing, dd..etc. OR if you have a tight budget (like me) get some radiator sealant! it's like at most 10 bucks for a bottle, pour it in and it should seal it up...hope this helps.
Pressure-test your cooling system to find out where the leak is. 1-800-RADIATOR will have a new one on your porch in an hour, if that's the problem. Most replacement radiators have AT cooling built into them.
Take it to a radiator place to have it pressure test for any leaks, I
had the same problem a week ago. My radiator was F@k up,
they applied pressure (AIR) to it and spray it with soap then is when
small holes you could not see before where reveal.
thnsk guys, weird thing is it nto leak like 4 days fo driving then suddenly leak. I go through coolant like crazy
