Radiator removal question 2g n/t automatic.
Tha Fella Dylan
242
Jan 9, 2012
Algonac, Michigan
My dd 1998 eclipse gs needs a new radiator and not being the best mechanic.... I was looking for some input from you guys on the difficulty of performing this. I have the basic wrenches but not much more. Can I do this at home with little experience? Looking to save $$ is all. Thanks in advance.
It's easy.
1-drain the water/coolant
2-unhook the hoses
2.5- unbolt tranny lines and unplug fans
3-unbolt the 2 brackets near the headlights that hold the radiator.
4-pull the radiator out
ed1380, you forgot that 2g N/T autos have tranny lines running through the radiator because the tranny cooler is located in the radiator as well. Its 2 lines, one in and one out. All 2g TURBO autos have a seperate tranny cooler that's not connected to the radiator. That being said, Tha Fella Dylan don't forget to top off your tranny fluid levels also.
Its not that hard and your first time might take a bit, just take your time and keep everything organized upon removal. As for the fans just unplug both of them and when you pull the radiator the fans will come with it. Once out you can easily unbolt the fans. The bolts are found on the corners of them.
Oops my bad. Edited.
I would also recommend that you pick up a Haynes, Chilton, or Factory Service Manual (FSM). Any (or all three) are a great resource to have!
