radiator fans, heater and windows help
jdigitty
155
Aug 1, 2009
lakewood, Washington
:confused::confused:whats up thankz for looking and im not sure if im putting this in the right place if i did or if im doing something wrong let me know well where do i start i just got the car did a tune up and yesterday put a remote start alarm keyless entry in it then we get to today windows arnt working heater doesnt blow and i live at fort drum veryimportant and the most important thing radiator fans arnt kicking in changed the relay nothing and i check where the relay pluges in and theres only power at one thing not sure if thats right thankz in advane:hellyeah:
and when you push the ac button the light doesnt come on is there a wire harness i might have unpluged or something thanks :hellyeah::hellyeah:
also tried takeing out the relay nothing again
I'm gunna say its one of two things. Either you installed the remote start wrong (most likely). Or your alternator is dead.
best bet is to find a wiring diagram and see if any of the wires you spliced into are common with the blower motor/windows/fans. relays are practically switches. there should be a wire with voltage present when car is in on position, when grounded, a coil inside magnetizes and moves an arm to connect a set of contacts.
  • Wanted 6 bolt NT water pipe
    • chrisman287
