Radiator Fan hard wire
Pitman99505
55
5
Aug 13, 2005
Charlotte, Georgia
I was just wondering if someone could give me a really dumbed down version on how to run your fans off of a toggle switch. I have searched, but the couple that I have found were kind of hard for me to understand. Thanks in advance!!:talon:
Very simple. Ground the fan to the chassis right off the bat. Run a wire from the fan(positive) to your switch. Then from the switch go to a power source. I used my radio fuse in the box to tap into, that way the power is "switched". So when the turbo timer shuts the car off the fan turns off also, or I can just turn the key to ign. and leave the fans on.
Awesome, but I know its a stupid question, but where are the fan positive and negative? I am a little confused on which wires are which.
Thanks for the link, I think I understand, bue let me check...the blue/ red is positive and the blue/ black is negative.
  • Wanted 6 bolt NT water pipe
    • chrisman287
