Racing with nitrous
nikkeebabee
253
Jul 21, 2004
Rochester, New York
For those that are using nitrous when are you spraying?
off the launch?
2nd?
3rd?
I'm not sure when i should start to spray the car....
background on the car:
95tsi awd
50 shot
evo 16g w/ supporting mods
sbr 3500 clutch kit
If you are launching with juice, how are you doing it?
I was planning on starting to spray in 3rd but i think thats way too late... then i was thinking 2nd because 1st gear is pretty short.. but then i wondered with the awd if i could just rip out of the hole with it... i figure 400 hp is 400hp no matter how it gets there.
Thanks in advance...
I have had good luck with Nitrous Express and their customer service is top notch. The window switch that I use has a first gear lock-out and it is a good thing! Why waste rubber when you don't have to? :cool:
My best advice concerning the spray is to start 'small' and work your way up to where you want to be. :cool:
Best of luck with your ride...
I use to start out spraying out of the hole, but all I did was spin all the way down the track.
I now just hit the switch that I have mounted beside me around the middle to top part of second if I can, especially on an 1/8 mile track.
