Quick question: Headlights
justnobody
148
Jun 30, 2007
Kearny, New Jersey
hey a real newbie here, right now i have ebay projectors on my eclipse, i wanna get stock headlights, i went to the junkyard and they told me they only have the Headlight Lamp only, not the assembley, just the lamp itself, and maybe some bulbs, no wiring or anything, would this be a direct fit when i take out my projectors, like the wiring or whatever from the projectors would work with the stock? if not you know where I can buy the wiring? so it'll connect and work with my car.
well its sonar projectors they're called ..
i want to get the stock oem 97-99 headlights, cause the guy i was talking to with retrofitting told me he only does oem...
and all the 97-99 headlight assemblys i found are $300, 400+ dollars even on ebay they're like $280ish .. when they told me they had the headlight lamp itself only, so i guess theres missing parts like bulbs and wiring? .. but for 40bucks, thought i could save alitte .. but wanna make sure before i buy it all the wiring on my projectors would be interchangeable with the oem headlamps, so i wouldnt need to buy any additonal stuff besides bulb.
I've put in 2 different sets of lights on other cars both of which were from ebay and they swapped right in... so my guess is vice versa would work just fine. or you could just get the stock lights and if they work.. great. If they dont then you have to buy the harness. no biggy..
I will sell you a pair of 97-99 headlights. They are slightly foggy from bulbs blowing up inside. It's not even that noticeable and can be cleaned out.
  • Wanted 6 bolt NT water pipe
    • chrisman287
