quick help with my logger
lowridin2g
904
Sep 5, 2002
Pembroke, Massachusetts
ok just got my logging software a couple days ago. i got a palm m100. i also just put in 650's and a 255lph pump. the logger works absolutely great, monitors everything i ask it to, when i go to a datalog you can watch the curves in rpm, timing and all that.
heres the problem.........when im in a log and i click go, do a thrid gear pull from 3,000 to redline then i click stop. save the log and bring it up. all i see is a small line, it only saves like the very begining of my pull for instance like 3695 rpm's. it worked fine the first couple times for me but now its not. anybody have any ideas why its doing this? from the logs i got before, my fuel trims were like right at 0%, my o2's were at .94 volts. i have my highs at about -36 and -37 on the safc.
back to the original question, anybody know why the logger is doing this? im gonna try resetting it and doing it again. oh yea and also the batteries are at half, so the batteries are not dead in it. :confused:
Maybe you have used all the memory and it can only log with the room thats left :confused: that my guess im just checkin forums because i plan on purchasing one of these soon and just seein how people like em.
nope, i have 92% free memory on my palm. batteries are at about half life. maybe the hot sync cable that i got from pocketlogger was no good, i have 2 others that i got with the palm, im gonna try them and see if theres any difference. :dsm:
welp i switched hot sync cables, and logged only 3 things at a time and got good results. here are my logs.
rpm LTFT STFT
3335 -10% 0%
3527 -10% 0%
3871 -10% 0%
4257 -10% 0%
4632 0% 0%
5015 0% 0%
5363 0% 0%
5703 0% 0%
6039 0% 0%
6328 0% 0%
6597 0% 0%
LOG #2
RPM TIMING O2BANK1
3871 25 .12 V
4191 19 .86 V
4582 10 .90 V
4949 10 .92 V
5359 11 .94 V
5695 14 .94 V
6035 15 .94 V
6320 16 .94 V
6589 17 .94 V
6832 17 .94 V
7070 17 .96 V
LOG #3
RPM TIMING 02BANK1
4031 16 DEG .94 V
4406 9 .92 V
4750 7 .96 V
5105 8 .96 V
5453 10 .96 V
5781 12 .98 V
6078 14 .96 V
6394 15 .96 V
6656 17 .98 V
THOSE ARE ALL THRID GEAR PULLS, what do u guys think????
yes i would have to agree my logs do look pretty good, a tad rich but i did a couple more if anyone cares. im just bored so ill post them. again third gear pulls:
RPM TIMING O2BANK1
2539 23 DEG .04 V
2730 27 .04 V
2882 26 .04 V
3113 23 .08 V
3429 14 .82 V
3812 8 .90 V
4222 10 .90 V
4621 9 .92 V
5035 11 .94 V
5410 11 .94 V
5773 13 .94 V
6136 15 .96 V
6449 15 .96 V
6746 17 .96 V
keep in mind i wasnt wot until about 3500 rpm's on that pull and i didnt go to redline. ON LOG # 1
RPM STFT LTFT
3300 0% -10 %
3574 0% -10%
3992 0% -10 %
4386 0% -10%
4792 0% 0%
5195 0% 0%
5558 0% 0%
5902 0% 0%
6230 0% 0%
6539 0% 0%
6824 0% 0%
MY NEXT LOG I GOTTA LOG THROTTLE POSITION ALSO i think that would help alot to know when i actually go WOT so i can tune from 3,000 to about 4400 rpm, from the looks i could lean them out a bit. but my highs on my safc are basically about -35, -36, -37, and i think -34 at redline. lows are -17, -16 then -15 all the way up. im gonna keep at it and take the gsx back to the track and get some better numbers :dsm:
