quick head question
peon_slayer
259
34
Oct 6, 2008
grande prairie, AB, Canada
ok so i have a 2g talon, with a 6 bolt swap. i am going to feed oil from my oil filter housing, now on the six bolt engint the turbo was fed through the head... so can i just put a bolt in the hole and call it good or do i need to do something special....
You can just use a bolt, but I would reccomend putting some Thread sealant or RTV silicone on it. I would also make sure you will not be over oiling your turbo when fed from the OFH. What turbo are you running? Search the forums for the oiling requirements for your specific turbo, find out what your oil pressure is from your OFH, make sure your not going to over oil the turbo and that will help prevent premature bearing failure
my turbo is a brand new forced performance hta 68.... i am not sure what the oil requirement is for this turbo and any help would be awesome.
1g oil feed line should work. Call FP and they will be happy to assist, I love FP support.
i do not have the factory line that is why i need to know what i can do to block off the hole left in the head. and i already have the steel braided line coming from extreme psi... if i need a oil restrictor what one will i need...
anyone? does anyone know which restrictor i will need?
