Quick DataLogger Question?
b4christ15
212
Oct 21, 2004
Randolph, New Jersey
I plan on getting a datalogger soon and have a few quick questions. Does having a 6 bolt powered 2g change which datalogging package to get. Also, what are all the things neccessary to start datalogging? Which palm, softare, cables etc etc. Thanx for all the help- Blaine
The motor doesn't matter unless you changed your diagnostic port. 2nd gen's have an obd-2 port, so you will need an obd-2 logger cable. 1g's have obd-1 ports (different plugs).
You will need a palm, mmcd logger software or tunerstein logger software, and a logger cable. If you get it as a whole package the only thing that will matter is whether its obd1 or 2. If you buy everything separate, you need to make sure that the logger cable is made for your model PALM.
Good Luck.
