Questions about slowboy UICP:
joe039
123
Jul 19, 2004
San Luis Obispo, California
So-
I've had this problem for a while that really pisses me off to no end, and i think it's time to rectify it:
Whenever i run any boost over 11 psi, my bov(its off an evo) pops out of the stock uicp. it's quite annoying having to pull over, whip out the tools and put that piece of crap back in. What i'd LIKE to do, is get a new uicp along with a new BOV.
here's my question: Will this uicp>> http://www.slowboyracing.com/more.php?id=1009& fit their fmic kit?>> http://www.slowboyracing.com/more.php?id=159&
Also, will it hook up with the stock sidemount ?
Pretty much i wanna know if it'll fit before and after i get a front mount.
thanks guys!
:laugh: you made my day
thanks guys!
The 2G BOV and EVO BOVs are crap. Both leak so good idea to replace.
The SBR UIP replaces your stock UIP lines and is not compatable with their FMIC kit.
The SBR FMIC kit comes with it's own set of pipes so no worries if you decide to upgrade to it.
Like was mentioned, that & most other pipes are designed to replace the factory routeing ic pipes. So these pipes will work with some fmic's such as the greddy, or apexi that are designed so their pipes will bolt up to the stock pipes. Now there are also fmic that use the short route for the pipeing such as the sbr or victory performance & they will not work with your stock or upgraded pipeing as they take a different route from the ic to the throttlebody. If you buy a kit from one of these companies they come with all the new pipeing. If you plan on running the smic for a while upgrade with one of the hard pipes, like the sbr one & if you eventually step up to a short route fmic you can just sell your upper pipe to someone as it will no longer be needed.
  • Wanted 6 bolt NT water pipe
    • chrisman287
