Question on clutch install
solisjulian
82
Jan 5, 2013
wooddale, Illinois
Okay so I'm thinking bout getting a xtd stage 4 clutch n wondering what do I need to put it in? Just a good OEM TOB? Or anything else
I don't have many mods kinda stock but I want a strong clutch that will last.
I have some experience with the XTD stage 4. I personally would not get that clutch again. I did ask XTD for a 2600 pressure plate. I installed it and it was a lot better than the stage 4. You would just need the pressure plate, clutch disk, alignment tool, (most likely comes with the kit you buy) new TOB, jesus clip for the TOB, new fork and pivot ball. I would also check my step height on my flyhwheel. You may need a resurface for the flywheel if you re-use it. I think if you have no mods and plan to keep it close to stock you cant go wrong with a new OEM clutch.
I got a gst now I'm just running 10 psi besides that I'm stock should I go with OEM then? What's a good cheap as good or better then OEM clutch?
Mitsubishi wants to sell me a kit for 250 I find that expensive. What's a good OEM kit
Or same or slighy better then OEM.
Are the luk autozine clutches good? They come with warranty
Are exedys good I seem round $100
I got like 150 LOL you don't think a xtd would be good then,? I just want sum to last me
I hear good n bad bout them some that last for weeks others that last for years
How long would a OEM mitsu last me
I'm not looking to get the car over 15 psi, would the OEM be good for me? Would it be able to handel
I got a 1g , n yeah just a MBC not anything crazy so OEM clutch would be best m last a good long time?
Thanks for the replies guys appreciate the help
