Question about TPS adjustment on 1g AT
92GSXman
308
Jun 12, 2003
Wilson, North Carolina
I have a 92 TSI and I'm getting a code 14 on my ecu and a code 12 on my tcu, both which have to do with the TPS. I tried checking the TPS voltage coming from the ecu, the manual says that each pin should read around 5.0 volts but only one of mine did. I then used the jumper wire test to try to test the voltage going to the TPS and got .72v, the manual says that I should have .48-.52 if I remember correctly.
I plan to take the TB off tomorrow and try to get .48-.52v like the manual says, should this take care of my transmission code too?
Why would only 1 of the 3 pins read 5.0 volts? I got a reading from the other 2 but it was no where near 5.0. If anyone can help me please do so. I've already searched and read through many posts but can't find my answers. Thanks in advance!!! :talon:
Because only one pin on the TPS is connected to 5v. That's pin 1. Pin 4 on the other end of the connector is connected to ground and pin 2 is the output to the ECU. It's voltage will vary as you turn the throttle from about 0.5v with the throttle closed and the TPS correctly adjusted to almost 5v when the throttle is completely open. The voltage needs to smoothly change without any spiking or dropouts.
Steve
Steve
OK, that makes sense! The Haynes manual kinda failed to mention that. The way I read it was that all three should read 5v. I plan to adjust the TPS today using the jumper wires to .48-.52 and hope that will solve my problem(s). Like I said right now it's at .72v so that's gotta be the problem. Thanks for your help!!!
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
