Question about MAF-T on a six bolt swap
horizontalkev
Supporting VIP
1,000
Jun 28, 2010
great bend, Kansas
Several questions, I bought my GSX with absolutely no knowledge of what I was getting myself into, and no way to contact the previous owner. (tHe guy I bought car from wasn't the original over, either). And now all im doing is learning about the car more.
Im trying to figure out injectior size, I figured id cheat and look at the MAF-T settings and see what its set for, is that an accurate way or could the overall tune settings not necessarily reflect injector sizing? And will I have to look at 1g or 2g maft instructions if I have a 6 bolt swap in my 2G?
Somebody also told me he thinks my car was setup and tuned for E85.. How can I confirm this? I've been using 91. Also
Did first gear pulls and looked at my timing, idle its 5-7* and WOT its goes all the way to 30*ish :confused: that's wayyy to much right?
What I know so far, 6 bolt swap, Rewired fuel pump (unknown type), stainless braided fuel lines, aeromotive FPR, AEM intake, AEM Fuel rail, tial BOV atmospheric, maft in blow thru, ngk wires & plugs.
All AEM gauges; EGTs, boost, coolant temp, fuel pressure and crappy narrowband.
I have absolutely have no experience with tuning and im learning slowly I love this type of work. Thanks for the help
Just pull your injectors and look at them. They should have a code branded on the side. And yes 30 degrees of timing is outrageous. I would keep out of boost until you get that figured out. Do you have a way to log knock?
Nope not that I know of. There is sometime of pocketlogger setup on the car through the obd port but the palm never worked so ill never know :). Its just a laptop connector that plugs into the obdii port and another adapter at the end of that for the palm
The cord to the car says
pocketLOGGER
OBDii Cable Rev 1.0
Copyright © 2002
Serial number 1100
OLD version of pocketlogger? Sounds severely dated
