question about fuel pumps
irjoshy
231
Mar 9, 2003
Elyria, Ohio
My mods are
-homade UICP
-1g bov
-k&n filter
-ACT 2100
-MBC
-2.5" turbo back exhaust
and i'm running at 12 psi but it peaks to 15
I ran a 14.6 in the 1/4... my car seems to flatten out in the high rpm's, even more so than any t25 dsm i've been in.... so i think its the fuel...
my question is if i installede a 190lph feul pump, would i see any performance gains...
for example, would it seem more steady in acceleration, or would i just gain more power?
opinions wanted...
Thanks
-Josh
Just slapping in a fuel pump and going can work if the boost is not higher than the injectors can take it, since you are running a lower boost I personally dont see a problem with that. I would recommend buying and aftermarket fuel management system, whether it be a piggyback system or standalone is your choice. On my 1990 TSI AWD I chose to get the Apex'i AFC-II to tune my fuel. The good thing about getting a fuel controller as well is that you can lean out your mixture a little more than what your stock ECU does so that in turn makes more power, if thats what your looking for. You should try the fuel pump re-wire for the stock pump as well, that gives a little more voltage to the pump which in turn makes the pump output slightly higher than what it does normally. I hope this helps :thumb:
With that setup you are not outflowing your current stock pump. You wouldn't get any gain from going to a larger pump unless your stocker is on its last legs and not flowing enough to keep up with demand causing a lean condition.
