q45 wiring
ECLEVO4G
117
Aug 30, 2007
Stone mountain, Georgia
Ok I have been looking and looking and still haven't gotten a straight answer from reading.
I need to know the correct way of wiring a q45 throttle body to my 2g gsx? need help asap trying to drive it home from the shop
Look at the harness and not the pigtail.
-Red is the 5 volt input wire
-White is the TPS signal wire
-Black is the sensor ground/return
And since you both are on 2g's..
2g tps harness:
1 - Green/Yellow (+5v Sensor Power)
2 - Brown/Red (TPS output voltage)
3 - Yellow/Red (IPS switch)
4 - Black (Ground)
