Push Or Pull ?
ShadeTreeDSM
269
Sep 16, 2005
Fort Lauderdale, Florida
what is the best type of fan for our cars ? push style or pull style.
personally i cant see pulling fans working to great because when ## driving wind pushes and looks like it can slow the fans down ...but i could be wrong..
so this is why im asking because i dont know...
let me know asap so i can purchase push or pull style fans !!!
thanks ! ;)
dsm_illicious said:
The factory design is pull type...stick with what's been proven to work...
what way are you talking about ?
here is how i see it.....
im looking at " the push style " as if i was standing right in front of the front bumper and the fans are pushing air towards the motor.
and i see the pull style the opposite way.
help :confused:
help :confused:
Picture the fan laying flat on a table, with the blade down and the motor side up.
A puller would pull air from the table through the fan. A pusher would push air through the fan and into the table.
(I might not have offered the best example, but I hope it helps)
99gst_racer said:
Run a puller style fan on the backside (engine side) of the fan.
You could get the same affect with a pusher style fan on the front of the radiator, but I don't believe we have enough space for fans in the front.
Actually, I run a single 10" pusher fan from a mecedes benz and it fits perfect between my fmic and radiator. I actually have it mounted on the passenger side and my oil cooler is on the driver side. It cools better than my stock or slim puller fans ever did. On a 95* day, I used to see average temps of 210* but now with the pusher, the highest I have ever seen is 206*.
no no that definetely did help alot..thanks alot..
i always thought it was the other way around...but this def helped alot..once again thanks !
i would do that but the front mount intercooler i have is to tall, so the fan wouldnt fit back there...what im gonna do is get 2 SPAL 10" fans and throw that on..i should get good water temps then ...
do you use a mechanical water temp gauge by any chance?
because i have one and the probe doesnt go in all the way into my thermostat housing so i have to use the stock gauge until i figure something out
Actually, my fan is located where my ac condensor used to be so fmic height shouldnt matter.
I am using an autometer electric temp gauge because the sending unit fits into the thermo housing perfectly. I also use my logger to monitor temp more than I use my gauge.
oh i didnt know you took out the A/C Condensor...i plan on keeping my A/C Condensor since i live in south florida where is it always hot..but thanks for your help !! :D
