Pulling the motor but need some suggestions.
iRepDSM
92
Jan 25, 2009
Medicine Hat, AB, Canada
So it's come time to pull my motor as i've come to the conclusion that my piston rings are fried.:notgood: I'm looking into just taking the motor apart and just getting everything inspected, replacing what needs to be while doing maintenance, cleaning, polishing and all the good stuff.
I am not looking into building it up with wiesco pistons and rods or anything like that, in the future for sure, but that's not my goal or priority right now. I just want a quick car with a reliable engine.
I just need some suggestions on what to avoid, what to look into that's worth doing so, and any tip that you feel are worthy of sharing since this is my first time pulling my motor out and stripping er' down.:thumb:
THANKS in advance
If you're going to pay someone to spec out your bearings and such, then you really don't need to do too horribly much. I'd replace the pistons if you're going to keep your rods - just get some cheap OEM ones. Of course, you're going to want to eliminate your balance shaft with the Mirage shaft while you've got it torn apart. If you're going to spec everything out yourself, then you need to read this book:
Amazon.com: Engine Builder's Handbook: Tom Monroe: Books
You'd also be looking at some money in all the tools you'd need to do the job right - and that's going to cheap route on some things like mics and calipers. Things like checking your head for flatness and for cracks you're going to have to leave to a machine shop. Some people like to use Plastigage for assembly - I prefer mics myself - I use Plastigage to verify my measurements are accurate. Just take your time and invest in a good torque wrench. If you really want to do all the work yourself, say so and I'll try to give you a list of most of the tools you'd need to do the job right.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
