Pulley Issues
Spaceape48
Jan 29, 2003
Was hoping to get some insight from you guys seeing as I know nothing about this, but am getting better. I have a 95 talon esi, decided to chage the pulleys because I have so many problems with the belt screetching and what have you due to lost tension.
I'm thinking of getting a pulley kit, the two I'm considering are the ATR underdrive pulley kit, and the other is the unorthadox ss 4 piece pulley kit. Do each of these come with the same pulleys? Do they have the harmonic dampner? Are these all of the pulleys that are found on my engine? Newb to the max I know,LOL.
I've looked around the forums some, and was unable to find much info about this in specific. I'm open to what anyone has to say about what kit to buy too, so if you feel one is better than the other please tell me why.
I'm looking for some rescources on learning more about my engine, any suggestions? Thanks to all-
:beatentodeath:
## doesn’t make a pulley kit for the 420a; they only make the crank pulley, which is a nice piece. Howellautomotive.com offers are cheaper solution to the pulley dilemma, the AFX UDP, which is basically the same as the ## unit. When you change your pulley make sure to remember the AC and PS belts adjusting screw is reverse threaded, everything should go smoothly, good luck.
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
