PTE/Delphi 780cc numbers?
turbo90gsx
654
3
Feb 12, 2004
Fort Wayne, Indiana
I'm having a hard time finding a place that has the part numbers for PTE/Delphi 780cc injectors. The reason being is because bought a set of injectors off ebay and I want to make sure that they are infact 780's. The numbers printed on the tops are 7014 and 17113742. There are more markings on the injectors but the first set of numbers are different on all of them, but the 2nd set of numbers are 12234. Thanks alot.
***EDIT***Wrong brand name
FIC doesn't have 780cc injectors...I have the 750cc injectors and all four have the numbers 125-750 engraved on them. The 125 means that they are for DSMs only and the 750 indicates that they are 750cc. Here is their product line for DSMs.
www.fuelinjectorclinic.com
MITSUBISHI ECLIPSE/EAGLE TALON/PLYMOUTH LASER 1990-1999
550 cc Peak & Hold #125-550L Set/4 $200 Lucas Injectors
550 cc Peak & Hold #125-550 Set/4 $280
650 cc Peak & Hold #125-650 Set/4 $255
750 cc Peak & Hold #125-750 Set/4 $255
850 cc Peak & Hold #125-850 Set/4 $255
950 cc Peak & Hold #125-950 Set/4 $350
1000cc Peak & Hold #125-1000 Set/4 $400
1600cc Peak & Hold #125-1600 Set/4 $280
I just checked mine out and FIC is also engraved on them.
I'd say those AREN'T FICs, but they may be an old model I haven't seen. I would have them flow tested.
I would check out at the PTE (precision turbo& engineering) website...
They sell injectors in 580cc-680cc-780cc-880cc+++ size so it's likely they either mixed up the names or you got jipped
You could always get them flow-tested
Sorry guys. I've mistaken them for FIC. They are actually PTE/Delphi. I'm still unsure about the part numbers however.
Rochester Rochester "PTE" RC Flow
Part # Rating Size Average
17113738 50 lb/hr 550cc 515cc/min (estimated)
17113741 55 lb/hr 580cc 535cc/min
17113814 65 lb/hr 680cc 640cc/min
17113742 75 lb/hr 780cc 748cc/min
17113743 85 lb/hr 880cc 840cc/min (estimated)
17113744 95 lb/hr 1000cc -
Someone posted somewhere but I don't remember where I just copied it to check my injectors. For what it's worth my PTE880cc numbers matched.
Bob
