problems tearing down engine
eagleowner87
30
May 6, 2004
waterford, Wisconsin
i'm tearing my head apart to see whats wrong with the engine because the guy said the rings were bad so i believe him till i pull the head i cant' get the head off i have pretty much everythign off of it and it still won't come off it pulls off on the cam side but the oposite side only has lifted a litte bit and still stuck down any one have this problem could help ,me it would be apreciated it is on a 94 talon n/t
I recently had the same problem except mine wouldn't budge at all. Apparently there is an intake manifold bracked that attaches under the intake manifold, I found it easiest to remove the upper two bolts.
yea i happend to look under the engine in the back and found it and i pulled the lower one and lifted the head right out now so now i have to find whast wrong wiht my engine
