Problem with Shifting
I noticed no one mentioned this. You should check the pedal adjustment, if the upper pedal stop is extremely mis-adjusted then you could have pedal pump-up which would keep pressure in the clutch hydraulic system and keep pressure on your pressure plate release fingers. Here is RRE's website which will explain the whole situation and how to adjust the clutch pedal. RRE's Clutch And Flywheel Tech Info
thanks 98 mits I have tried that before i started the project and it didn't work. LOL and seeing how I'm 80% of the way with disassembling my trans i think i would go ahead and replace the clutch anyway LOL but thanks for your input hopefully someone will learn from this thread
  • Wanted 6 bolt NT water pipe
    • chrisman287
