Problem With Fog Light replacement
tonygst
214
5
Oct 21, 2004
Twin Cities, Minnesota
I have 1 burned out fog light and there are three screws that i undo and the assembly is sopposed to come apart and i can change the bulb after that. I unscrew the 3 screws and i can't seem to find a way to get the bulb out. Any suggestions on or instructions on how to replace this bulb?
I feel like a newb but its come down to any help is great.
Note:
Dealership will replace it for $60. I said forget it i'll try myself.
If I recall while changing mine, there should be 4 screws. After those are out it should just come apart. If you don't figure it out I'll take a look at it tommorow morning.
i get off of work tommarow at 8, so i'll double check tommarow night, shoot back to me and see what your found. thanks. :thumb:
I tried messing with those phillips screws and gave up. A better way IMHO is to just unbolt the entire housing/bracket assy from the car(3 hex bolts? ) unplug the harness and drop the whole thing out the bottom. Took like 20 minutes to do both sides. :)
thanks defiant, i did try and search and i even tried google, i didn't mean to make another thread.
But i'll follow that other thread and anyone else that has any suggestions i'll give it a shot. Thanks guys.
:dsm: Forever
