Fog Light Problem
BenHooker
76
Jun 30, 2008
Seminole, Florida
My fog lights haven't been working since I bought the car so I finally decided to check into getting them fixed. The housings have bulbs but when I checked the fuses in my fuse box, I surprisingly had three fuses that didn't work. I replaced the fuses but they still failed to work. What could be the problem?
Check to make sure the bulbs are good, check the foglight switch itself, check connections to the back of the foglights and the back of the switch, as well as all wiring.
time to get out the testlight......see if the bulb or harness that plugs into bulb has power...if not check switch.......then fuse box
Check to make sure the bulbs are good, check the fog light bulb switch itself, check connections to the back of the foglights and the back of the switch, as well as all wiring.
Hi there, sorry for bumping on this thread, i am now facing the same problem, my brother checked all the wiring of the light and he said everything is okay. Should i actually replace the fog light bulb?
  • Wanted 6 bolt NT water pipe
    • chrisman287
