Power Train Twin Disk clutch help
purplehazetsi
277
Oct 14, 2002
Berlin, Connecticut
Ok, im not a newbie at the dsm world, so please if you have experience with this clutch then help if possible.
Ok well i bought the PTT twin disk for my 6bolt. Its really a nice piece, anyways i mounted the flywheel and went to bolt up the pressure plate/disks and im using a normal 1g alignment tool. Well the tool fits snug in the center hole of my fidanza, but the PTT flywheel has a little more room which is making the tool sloppy. Anyone experience this before? i called ptt to see if i needed their own tool but they said any tool for a DSM will work.
My alignment tool is made of plastic and cost about $1.00 when I bought it from Advance a few years ago. It worked well when I did my PTT install. I can't remember if there was any play, but hey if PTT said you was good to go, keep going. I HIGHLY recommend the Isuzu slave cylinder.
