post your system
Sub isn't done, so there's nothing to show but an old MTX sub in a generic box.
Front stage is Boston Pro three way with tweeter and mid in a pair of Q-form kicks and mid-bass in the door. No rear fill.
Head unit is an Alpine CDA 9835. The Alpine has the EQ, crossover and time alignment built in and eliminates much of the stuff I used to have
Amps are Precision Power A600 (150x2 into 4ohms) for the front and a 1985 Rockford Fosgate Punch 150 (150 x 2 into 2 ohms) for the single 12" 2 ohm DVC Image Dynamics woofer that will go into the tire well.
The front stage sounds great. I have 7ms. delay on the driver's sided and roll the tweeters off up top. The A600 drives the Bostons superbly and shows no sign of strain. They will play quite loud before they noticably compress. I was looking at Dynaudio but they're expensive and the exchange rates are making this worse. The spare tire will sit above the sub enclosure on a custom mount, both guarding and concealing the sub.
I've seen others do this and it looked like a good idea.
This is goofy as I intend to get on a car with an external wastegate and 3" exhaust :)
2 Hybrid Juggernaut 12s. Dreadnaut basket and motor assembly with a Juggernaut dustcap. Dual .7 ohm voice coils.
Second 12 Volt Battery
0 Gauge
Modded Earthquake D3
The amp will produce around 5500 watts if the power supply is there.
The box was custom built for a 240, hence the odd fitment.
oh my god in heaven.... thats got to be really loud
I don't have my system in my car anymore cause of the roll cage and tried to save some weight. I'm going to be making a new setup this winter. I'm getting a JL12w7. I don't know how I'm going to build it yet, but it has to go around the roll cage and my new fuel cell... so its going to be tricky.
I have 2 10 inch JL's 2 amps, 2 custom boxes in the front floor area, i would post the pics, but i dont know how let me know how if you want them. :dsm:
There is a button bellow SUBMIT REPLY that says Attach Files. Go to UPLOAD/EDIT PHOTOS and a window will pop up. You can select which pics you want to add (700x700 or less please) then click UPLOAD. It will say which files your uploading on the main screen. When you finished uploading select SUBMIT REPLY. Done!
Clarion VRX935VD 7" touch screen with dvd player, 2 5.6" clarion headrests, memphis HC250D class d mono amp, 2 10" RF punch z, RF fanatic X 6 1/2" componets up front and same 4" componets in the rear
Thanks for the comments. No, I have never had the setup metered. It's out of the car moment getting some more upgrades to make it louder :sneaky:
Yes, it is really loud. I have the amp gain on like 10% and the wipers jump off the windshield. The local sound ordinance is 25 feet and in the words of the cop that pulled me over "You had it beat by atleast 10 times"
ROFL :D :thumb:
ROFL :D :thumb:
Lol, nice setup. I love Mmats. I had an extended cab silverado z71 with 2 juggernaut 15's in it powered by 2 us amps 2000x's. Those things are insane. We put 3 layers of dynamat in my roof and it still rattled as if you had a piece of tin and were shaking it. Never metered mine with both juggs, but with 1 I hit 154.7 on the dash, so you should be able to do that no problem, even with just the hybrids. How much airspace you running? What are the ports tuned to? I had 14 cubic feet or airspace. Now I am just running some Mmats pro-cast subs, but I am wanting to swap to the dreads.
Thanks. I don't think I'd do too well right now seing as I have 0 sound deadening for the time being (not sure how much longer I'll have the eclipse - don't want to invest in peel and seal). EVERYTHING rattles. Tail light bolts, hatch, the wing, my center console flexes, doors flex, wipers dance, etc. Lots of loss right now. Airspace is around 2 cubes per side (divided box). Ported around 40-42 hz.
2- ALPINE Type R subs
2- ALPINE MRP-M350 Amps (1 for each sub)
1- MRV-T757 Amp (component amp)
ALPINE IVA-D900 Monitor
ALPINE Type R 6.5" Components up front
Lots of fiberglassing and custom components in the install. sounds excellent, and since the pictures i've added another set of Alpine Type R 6.5" midbass speakers in fiberglassed kickpods up front as well. any questions, feel free to ask, or visit my webpage for more info and pictures!
Enjoy!
~Kurt
Clarion755dz with 6 disc changer (which i keep moving from side to side as I change my mind)
[But keep your pics to legal size.]
mbquart 5.25 components in qform pods (save your money and build your own guys, they aren't even enclosed, and don't even have any internal structure).
Kicker comp 6" subs in doors, and older alpine 3 ways in rear (blue cones)
All powered from a JBL 755.6 amp.
Notice the amp is turned 90 degrees and the changer is on the driver's side in this old pic.
That changer's tiny size is the reason I don't want to change to a non clarion head.
and a little led illumination here and there.
Just sort of a piece together system right now, to try out the concept and get me by until I can replace the speakers with JBL components (6.5s this time) upgrade to nice 8's in the doors and a single JBL power 12 with a JBL 600.1 out back. probably in the right pocket or under the floor.
  • Wanted HAFE/BEP external gate manifold
    In search of/want to buy Old school exhaust manifold with external wastegate flange. Preferably...
    • Jacob5se
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
