Post your free mods here!!!!!
XxrusianxX
114
Jan 18, 2003
Brookline, Massachusetts
I think it woudl be fun to see what people have done to their cars for free, please give us your results as well. I'll start.
Boost controller selenoid restrictor removal mod: worked extremly well for performance but turbo statred to squeel shortly after, still running like that though.
Radiator fan bypass: works well when i need to cool my engine after a race, gives me the edge on onther people with hot engines.
Intercooler flush: did not see a difference.
Most of the free mods that are beneficial have been listed on this site. I had a hard time modifying the BCS so I built a MBC. Less than $15-10.
More to come when finished of course. Details will end up on my blog, http://mavisky.blogdrive.com
i painted the tailights with a 4" stencil i made and can of spray paint i found in my garage,although i never finished them. if u have some small piping layin around,i saw on here someone replaced there stock dump tube with a hard pipe so it made the bov louder and it looked nicer too. i took the screen out behind the flip-up head light by the intake, and the screen behind the intercooler. i also removed my foglights so more air would get to the intercooler.
What exactly were you planning to do to finish them?
i wanted to finish the blinker and center peice. but i had to sell my talon before i moved because i spun a rod bearing and didnt have the money to tow it to florida :(
talon96tsi said:
How about porting the stock o2 housing, exhaust manifold and the turbine housing as well.
Exactly, the best free mods which rarely are looked at as free mods.
yeah i ported my mani and my o2 housing and the difference in spoolup was like night and day. didnt port my turbine housing though, i dont see the point with an 1 1/2" long crack in the housing.
Should have at least port matched it to the manifold and a 7cm gasket while guarding against boost creep as well.
I cut a large square opening behind the Side Mount, wide enough for two lengths of gutter guard to be bolted in. Very easy took me about a half hour. I used a Scheffield razor knife to cut the splash guard. Cut thorough that thing like butter. I dont have any data to show if it was in improvement but im sure increased airflow will def. give some kind of improvement. :thumb:
Here's a good one for newbies.
when installing a boost controller get a spare egr solenoid and hook it in parallel with e boost controller. That way when you try and run 1,000,000 psi the computer steps in and saves you from having to ask us why your motor blew up
I'm sure I have some form of smart ass comment for that, but I'll save it for a rainy day this time.
Another cheap mod would be the "greyforest hood vents".
black92_tsi_awd said:
xveganxcowboyx said:
What did you do to that poor light! OMG
I think he was making a air duct....
How about just buying one off of me: Headlight Duct
Well I could've paid someone to do it for me too, The point was to do it myself :D :thumb:
Plus once finished mine will actually carry the air past that second metal barrier yours stops at. That way the air is directly aimed at my air filter since it's moved a bit from the normal location.
