Polishing 102 (my version) for the Noobies
dvbrien
87
24
Nov 3, 2005
Rockton, Illinois
I just had to post these pictures of the polishing job I did on the 20g, I think I did pretty dern good! "I feel pretty, oh so pretty..."
Then I got real carried away and pulled my valve cover shaved and polished that too... If you look real close you can still see the ghosting letters coming through at a slightly differently color. I think it is because where the metal was thicker it changed the chemical makeup of the aluminum when heat was added over a long period of time.
If you'd like to know what I did to polish everything... I used a 100 grit in a palm sander, (20 min) 4 pads, then repeated with 160 grit (20 min) 4 pads, Change your pads frequently, the aluminum is absorbed quickly into the paper. I then used a corded drill to power buff fine scratches with a pad that resembles a rough scotchbrite pad (45 min), Creates millions of tiny surface scratches that eventually blend the contour of the housing. I'd suggest using an abrasive polishing wax during this process every 5 min. Then get yourself a Buffing wheel (not the cushion, 2 seem stitching style) get the one that spirals from the center all the way out to .5 inch of the edge. Home Depot $6 dollars (where you get the wax too). Put on a Good quality grinder, use a finer wax for polishing metals and then... buff away! No elaborate long process necessary. When I got to the Buffing grinder wheel, I had an hour and a half invested; it took me 15 min. to complete the job.
With the Valve cover, Repeat the process after you grind and file the letters flush. 3 hours! But well worth it... Be prepared with Drinks within arms reach! :) Don't Be Scurd, Just do it! Do it!
Man that looks real good... I still need to get one of those. I am working on getting the video back up for you guys.
dvb
dvb
Well, thanks for the informative post. Complete with pics of a job well done. Nice.
:thumb: to you other guys too. Some nice work there.
This is a great thread. dvbrien, make sure you add all the info you can to your tech article, including links to your video, etc. You can always Add to your article instead of editing it everytime. Also, if you could, please Attach your images to the article instead of linking off to an external site. This way, if that site ever goes down, we'll still have the photos.
Nice job.
Video from page 1 working again...
How would you like me to attach this?
OK guys I had to do it!
Oh, no! Not me! I had a polishing guy do it for me. I still have to go back over it with cream to get the "Whoa" effect.
Sorry, I had polishing envy!
Good job Bro... I was just thinking, That thing is bigger than the Turkey we had on Thanks Giving! LOL
D.
HEHE!!!! thanks, I think you gave me the bug because now instead of buying a hyundai valve cover I'm having my polishing guy knock down my stock valve cover and get that bling out!!!!!
i know this is old but i did my cover too after reading this article..I bought a hyundai cover because it was less things to file down.. went to home depot they had a kt of small circular sand wheels for 12bucks that attach to drills..and the 60 grit ate through those letters in 10 min. its no the greatest i stopped at 1200 grit but i still wanna sand up to 2000 grit it doesnt match my jmf heat shield and im pissed.. total time for the finished product you see here is 6 hours..including stripping the paint and sanding from 220,400,600,800,1000 by hand, then polishing
