pls help sounds like manifold leaking but not sure
japok
Nov 29, 2005
toronto,
hey guys im hearing this noise sounds like manifold leaking but only when the engine is cold but after warming up its gone.hope u guys have an idea what this is it bugs me a lot thanks
Could be possible I guess. The metal would constrict when it's cold making the crack larger, then when it heats up, it makes the crack tighter...
Could be, but you need to find the crack to make sure. Can you see the crack?
Are you sure it's not the lifters your hearing?
So many different noises can come out of these motors....
  • Wanted 6 bolt NT water pipe
    • chrisman287
