4gfun
Supporting VIP
- 2,012
- 56
- Dec 10, 2007
Ask Me,
Virginia
Hi,
This will be one of my first (if not my first) attempt at posting a log using mmcd 1.8g. I used MMCD tools to convert from pdb to csv. I logged it at idle (hitting the stutterbox a few times as you can see). It is being logged at idle as a starting point and since I am having trouble getting my 2nd gear pull off of my pc right now.
History and tune:
My vehicle is having a problem where it starts misfiring at about 5100 rpm and doesn't stop at higher RPM(s).
The problem is more persistent in 1st and 2nd gears and my logs will be taken in 1st and 2nd gears (for now) for now due to Virginia's very strong reckless driving laws.
The vehicle is boost leak free with new NGK blue wires, NGK BPR7ES plugs gapped at .028 (smaller gaps don't help the problem), and I have already tried another coil pack. I am running a pre-cat open cutout. Fuel pressure is stock. New fuel filter and fuel pressure is reading ~37 psi at idle. Injectors are FIC 650's.
Base timing is set at 5 degrees BTDC.
Compression is ~164 in all cylinders and the pistons are 1g.
Boost is at or about 18 PSI via my Tial external wastegate. MBC is not involved at this point.
The vehicle is tuned with RT Tuner Pro and fuel cut has been disabled in the tune. I have an Innovate Wideband and I am running the vehicle on 93 pump gas. All other mods are listed in the profile.
I have a tune that the previous owner set up on this vehicle, the vehicle used to run fine on it but now this problem has appeared. My point is that I have run different tunes with different timing advance and fuel curves (stock 2 g timing map and 10.8:1 A/F ratio) but the problem persists.
I am looking down at my wideband when I am doing WOT pulls and it is reading anywhere between 11.3-11.7 @ WOT which I am sure is on the lean end.
Questions:
1) Is the attached log how you want things to appear to troubleshoot this issue?
2) Is the attached log how you want things to appear when the issue is fixed and I want to tune for power?
3) I intended to show injector duty cycle but I am seeing what seems to be injector pulse width in milliseconds. Am I logging the wrong parameter or am I doing something wrong?
4) I have tried to log my wideband because most posts on this forum seem inconclusive as to whether or not the results are accurate.
Thank you for your time.
History and tune:
Questions:
I ask questions 1 and 2 because my laptop serial port is on it's way out and I am forced to use very unreliable infrared so I want to get this right without making alot of revisions.
