please help will pay money!!
1fast97gsx
4,517
17
Jul 6, 2003
Orland Park, Illinois
hey guys ... I have a question about a 1995 talon esi. There is a harness by the throttle body that goes to another harness and they each have 5 wires. 1 ground and 1 for each injector I believe. Anyways, this is the main harness for the injectors. The wires on 1 side of the harness are a totally different color than the ones on the other side. My car has been messed with by the previous owner and both harnesses but off. The wires were just connected in a random order so the car has idle problems. I need someone to tell me what color goes to what color on these 2 harnesses. It should be easy to see and I will pay someone!!! Need help asap!!
yea man that'd help me so much. I don't have a digital camera ... maybe I can get one tho tomrorow. Should be just 5 wires per harness and I'm assuming the thick black one goes to the thick green one. The 2 harnesses connect kinda under where the intake goes to the throttle body. Its hard for me to say since mine have been cut and spliced and what not but you should be able to easily see it. Thanks a lot.
If you have a Haynes repair manual, they have an entire section dealing with the chasis electrical circuits..i think it be your best solution..you cant gowrong with it. SImpy identify and understand what component is in the area you are talkin about( aint sure but i think you are lookin at the ISC,TPS and theEGR area)And then look at the circuid diagram, it will tell you exactlly what wire, what colour goes where.....good luck
OK heres what i got three pictures and a "paint" diagram LOL I hope its whatyou need.
OK the top right hole is a black wire with a red line in it.
bottom left hole is a green wire with a red line in it.
justto the right of thaat there a yellow wire with a green line in it
to the left of that theres a all yellow wire
and all the wayto the right theres a green wire with a black line on it/
anymore questions let me know. :thumb:
yea that's the harness I am talking about. Now if you look at the other side of the harness ( the harness it plugs into ) all the wires on that side will be a different color than the ones in the pics you posted. I need to know what color goes to what color because the previous owner cut off both harnesses and just connected all the wires in a random order. It's too hard for me to match up because I don't know anyone locally with a n/t 2g. But yea that's the wires I'm talking about. Thanks so much for your help. If you could let me know the colors of the wires on the harness it plugs into and match the colors up I would really appreciate it. Thanks. :thumb:
OK the top right (black and red) get the green wire with orange line
the bottom left ( green and red ) gets blue with a red line
the next over ( yellow and green ) gets yellow with a SILVER LINE
the next one (yellow ) gets orange
and all the way to the right ( Greeb and Black ) gets white witha blue line
you get that ?
