Piston ring end gap
92awddsm
DSM Wiseman
4,877
93
Jan 17, 2004
Chesterfield, Virginia
I will soon be assembling a long rod 420a turbo engine so I am trying to gather good information from those experienced in the matter. My question is what end gap is everyone running on the turbo 420a? I would assume that gap would be a little looser than factory specs due to higher heat concentration on the rings but I would rather not make any guesses.
I just used whatever JE specified on the included spec sheet... I don't remember what that is off the top of my head. Who makes the rings you have?
I ran .017 on top ring and .019 on middle ring on my first engine. On my current engine i have .020 on top and .022 on middle ring because i am planning on spraying the hell out of the engine. BOTH engines burn a little oil but not bad at all. Both engines also had a lilttle blow by. They both pulled the same amount of vacuum as well. Every engine i build for now on will have the bigger gaps because if i want to spray i can without having to worry about the rings being too tight and i dont see any advangtage of the tighter ring gaps.
I have the Wisecos and when I called them and told them it was going on a turbo set up with maybe some nitrous they told me to gap the top at .016 and the bottom at .019 with a range of +or - .004. I gapped mine at .016 and .019 and I don't have a problem but I am not boosted yet. I get good vaccume and doesn't burn oil. That is for the non coated Wisecos, don't know if coated would make a difference.
  • For sale 2g 2G OEM Non Cruise Throttle Cable
    2G OEM Non Cruise Throttle Cable $50 + shipping & paypal feesYou must be registered to see...
  • Wanted 2g 1995 Eclipse GS-T Driver door cap wanted
    I'm looking for a 1995 GS-T driver side door cap or even a complete door with the proper door cap.
    • loco4G63
  • Wanted 1g MB668570 front ABS Ring for 1992 D27A
    I would really need front ABS rotors for my 1992 D27A eclipse with AWD. Would really appreciate...
    • Gurkigg
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
